跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Is the problem in power ic? Dead iPhone 7
Hello, I have a normal iPhone 7,
it just turned off while i am using it
I went to the store because I expected the screen problem and he told me that the screen and battery had been changed and the problem was not solved
He told me that it might be a problem with the ic power
I just tried it and when I put the charger , the area marked in the picture is getting overheat Then the Motherboard getting medium heat
Is there anyone who has experienced like this a problem and knows the solution or cause of it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There is shorting on the circuit that produces heat. Might be or might not be the issues of power ic. One thing remembers is that shorting on the circuit is the main culprit for that issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Senpai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 399
