Touch screen and volume only work 20% of the time
On my 2014 Altima SL the volume and the touch screen the changes my radio stations and operates my nav system only works 20% of the time. At times my volume will turn up 5 to 10 mins after i try to turn it up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Hi @jtleaf,
Does the volume change normally every time, if you use the steering wheel Volume buttons?
完成的
No it is the same problem
完成的
Hi @jtleaf
I don't know the answer but the steering wheel buttons connect to the AV/Nav control unit, so since they're not working properly either it may be that the problem is in the unit itself.
完成的
I have to agree with jayeff. If the volume control on the unit isn't working properly, and the ones on the wheel do the same thing, I strongly suspect the unit itself may be the problem
完成的
添加一条评论
