My laptop is not turning on. No charging lights.
I was working on my laptop in the night and i shut it down. I turned off the charger but left all accessories attached including a second screen which was also turned off.
But in the morning it didn’t turn on at all. Turning on the charger did nothing. No lights turned on showing if it was charging or not.
I tried all the basic diagnostic but in vain. I really need help. My parents would be super angry.
Model: Asus ROG G531GU
6条评论
When you say you turned off the charger what do you mean? Unplugged it from the laptop or unplugged it from the power point?
What diagnostics did you try?
由 mike 完成的
I only turned off my charger. I didn’t unplugged it from the socket or the laptop because i had to use it in the morning.
Also by diagnostics i meant i tried everything that was suggested on the internet like unplugging the battery and drain all the static charge by holding the power button. But it didn’t helped.
由 Ishant Kumar 完成的
@Ishant Kumar
Leaving chargers connected to any device while unplugging from the power point is generally bad practice as it works in reverse and once it is depleted draws power from the device possibly stressing internal components.
Did you take out the CMOS coin battery to reset? This video should be close enough:
https://www.youtube.com/watch?v=jQZHgdCu...
and more detail:
https://www.asus.com/support/FAQ/1005740...
由 mike 完成的
Thnx for letting me know. I will never leave charger connected to my laptop again.
由 Ishant Kumar 完成的
Hello, I have the same trouble with my laptop, any update about how to solve it ?
由 Brandon Jimenez 完成的
显示更多的1条评论
