跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
How to reconnect #3 cable on iPhone 3GS
I replaced the front screen on my iPhone 3GS but I am having trouble getting the #3 cable to slot back in under where it came out. #1 and #2 seem to press down onto their connections whereas #3 seems to need to slide under it. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Hello,
The #3 connector has a little black or white tab on the side opposite where you slide in the connector. You need to gently lift this tab, and then slide in the connector. Without this tab lifted, it wont accept the connection. Once the connector is inserted, press the tab down and it will be secure.
Hope this helps,
Xico Solutions
这个答案有帮助吗?
得分 1
1条评论:
I did figure that out and got it connected - now the phone will not power up when it is put back together. What most likely did I leave undone?
完成的
添加一条评论
If you have it connected and the phone will not power up, it may in fact still be the same connection. If it is loose/not done properly, the screen will not turn on. It's happened to me a million times- take it apart again and retry the #3. Make sure it is in far enough (but not too far).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,084
