跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iPhone 4 bottom broken screws
Good evening everyone. First of all I want to say that I've searched first for a similar fix but I couldn't find any. So I have this pentalobe screws on the bottom http://www.pda-spares.co.uk/image/cache/... . Sorry, no live pic cause my best camera is my iphone and i can't really take a pic of itself. Anyway, the thing is, one of them is more like a circle..I tried to unscrew it with a normal screwdriver(i know, stupid me) and i damaged one of them. I don't really want to get them out right now, but it bothers me and I'm afraid it might be stuck there? Any way to get it out ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hello,
This is a very common mistake, and luckily has a few easy fixes:
1) Try a simple flathead screw driver. Even tho it's rounded, there will still likely be a ridge for it to catch on.
2) We use a cheap screwdriver (ones you get from normal repair kits),put a small dab of super glue on the end of it, attach it to the screw and let dry. This should work to at least loosen the screw.
3) If both those fail, you can drill out the screw head and try the above methods again. The screw may break off the head, which leaves the rest of the screw in the backplate. You can get a new backplate from many online places for as low as $10.
Hope this helps,
Xico Solutions
这个答案有帮助吗?
得分 2
1条评论:
God bless you, sir.
完成的
添加一条评论
添加你的答案
Theo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 11,360
