跳转到主内容
Why does my monitor turn off but my pc stays on?
My computer was fine for the first 6 months. However after a while it began having some issues, when doing any activities (gaming, school work, YouTube) it would randomly shut off, making a buzzing static noise through my headphones, however my pc would stay on, the only way of fixing the issue was forcing it to shut down by holding down the power button (which I know is bad) it would then turn back on and the monitor would turn blank, any input would disappear. I would have to hold the power button once again, the strange thing is after doing this sometimes my graphics drivers would be removed.
specs:
Ryzen 3 2300x
rx 570
500 watt cooler master psu
16 GB DDR4 ram
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi @joelfathers ,
Have you tried a different monitor (even a TV on HDMI)?
Does it also do this in safe mode? If not then it is a driver problem.
Also run a sfc command to make sure that the system files are all OK
Sounds like a problem with the GPU card if the drivers are being removed when starting again as it is not being detected.
Can you try another GPU card to see if it is the card or the motherboard?
完成的
Hey @jayeff
I have tried multiple monitors, and a tv with a hdmi whilst watching films.
I will have to try this in safe mode. But I presume the issue will persist as it happens even in the windows boot up screen.
I do not own another gpu to try this with, I’m a bit sceptical to take it into a repair shop as my last pc that went into one came out corrupt.
Thanks
完成的
添加一条评论
2个答案
已选择的解决方案
This was solved with a new PSU for me. Works perfectly fine now no issues anymore.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Monitor turning off while you are actively working means that either your system is very confused on power management and told display to go to sleep, or GPU/PSU is having some problems.
Several issues can cause a monitor to turn off randomly. Some of the reasons relate to the monitor while others relate to the computer.
  • Monitor overheating
  • Loose cable
  • Bad monitor
  • Video card or motherboard problem
You can just troubleshoot these components and fix it accordingly.
这个答案有帮助吗?
得分 2
5条评论:
Sorry to say but no, its none of the above because it happens when I play the ps4 as well. So you obviously don't know and just making things up. It only stops when I use and external power source "Jackery" for my monitor and no more shut offs while gaming.
完成的
@joelfathers Good to hear that. :)
完成的
i have the same problem its started when i playing COD MW2. and now it's happening every minute with many games .
完成的
@Hamza Mukatrin If the cables is not bad. It's possible the game is out of sync. You can also try to update your graphics drivers as another easy solution. :)
完成的
@Albert I have the same problem. It started just a few months back. I have played Fortnite for about 2 years on this laptop and it never happened, but a few months back my screen would randomly go off with this glitching effect and it started going even worse. Whenever I opened up any game I was able to play for about 1.5 minutes, then the screen would go black. I have tried updating my drivers, updating windows, verifying game files, and so on. I would really appreciate anyone's help.
完成的
添加一条评论
添加你的答案
Joe Fathe 将永远感激不已
浏览统计数据:
过去 24 小时: 56
过去 7 天: 433
过去 30 天: 2,034
总计 19,650
