Happening to two different ps3
this is what I am getting I’ve had a PlayStation three slim for a number of years and open till a few weeks ago it worked fine and then all of a sudden it started freezing and I will get these different colored lines through the screen and it would freeze up I’ll have to turn it off and turn it back on and sometimes I wouldn’t get a signal back to the television and I will take me a while to finally get the signal back and then eventually it would freeze and get the colors again so I went on eBay and bought a brand new not a brand new a new used PS3 fact that was backwards compatible and I’m having the same issue with I’ve looked on YouTube and done all the tutorials I don’t know what’s going on how could the same problem be with two different PlayStation’s what’s going on could it be the wiring the television I have no idea
9条评论
Have you tried hooking up to different TV units to see if the problem persists? Using different hdmi cables?
由 brandon k 完成的
Yes same issue How can two different PlayStation’s have the same exact issue
由 D Key 完成的
@D Key
Have you tried using different video output types other than HDMI from the PS3 e.g. component video or composite video and checked what it looks like, you didn't say?
由 jayeff 完成的
You mean on the red white and yellow cables yes I tried that and in the same result I’m dumbfounded how the same issue could be happening on different TVs with two different PS3’s it’s a mystery it’s baffling anybody who can solve it I’ll Send $50 to
由 D Key 完成的
@D Key
Really stupid idea but have you tried a different power outlet for the PS3? Is it connected to a powerstrip? If so connect it directly to a power outlet.
Different TVs, different TV signal input types and cables, different PS3s, same video output problem, you would think that there has to be a common link somewhere?
由 jayeff 完成的
显示更多的4条评论
