跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
298 个问题 查看全部
After fall digitizer broke and back cover edge is a little bent
iPad 2 has fell on the ground and the digitizer broke. Unfortunately the edge of the back cover that hit the ground is a little bent too.
Is there any way to avoid replacing the back cover?
If I try to install a new digitizer without replacing the back cover will I have an issue during the installation?
Thank you in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个回答
已选择的解决方案
Theo,
Unfortunately you need to replace the back cover as well. Even if it is slightly malformed the new glass will not sit down and you will either be breaking it again or fighting it trying to keep it stuck down and dust and dirt will get inside.
这个答案有帮助吗?
得分 2
添加一条评论
I attempted repairing my housing, and it's not bad I would say, I used a mini chisel with pointed ends, after taking the skinny plastic frame off...
Now it's not skewed, and have fitted it back in and taped it up from the outside to see if it's a perfect fitt.. Well it will never be perfect, but as long as its out of the way of the digitser glass...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Theo 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 1,363
