跳转到主内容
Repair and assembly guides for the Honda General Purpose Engine model GXV160UH2.
1 个问题 查看全部
Need general tips and advice for fixing up a broken lawnmower.
Hello, I need some general tips and advice for fixing up an old lawnmower. I haven't put any fuel or oil in yet and tried to fire it up, should that be my first step? If so what next? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It depends. I would put some oil in it and it a couple of times by pulling the starter just to see if it is seized up or not. Give it a good cleaning. And check the blade to make sure it is on tight. Smell the gas to see if any left and if it smells bad. If it does pull tank and carb and clean. Check spark plug and make sure it looks OK. Then try to start it.
这个答案有帮助吗?
得分 2
2条评论:
Thanks man. I'll give that a try and see what happens and possibly ask another question or two ?
完成的
Ask all you want.
完成的
添加一条评论
添加你的答案
Heinz Beanz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 55
