跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1484 个问题 查看全部
ear phone no sound, everything else is working
Hi!
I had water in, but could open all and dry it out with rice. Everything is working fine now, only the ear speaker doesn't (earphones and room speaker work perfectly).
I tried to clean out the earphone jack as it was explained in youtube, but no effect. Is it possible that one of the cables 1, 2 or 3 is responsible for the ear speaker? Could I have replugged them badly?
Thanks for all answers!
Markus
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
you need to reopen the iPhone and check all the cables to make sure that none of them got unplugged, if they did, that could explain a lot of your problems, even if 1 cable is unplugged it could be your problem, even if its at the bottom of the iPhone
这个答案有帮助吗?
得分 0
添加一条评论
Thanks!
Yes, indeed! It was cable 3 (the small one below cable 1) which is difficult to plug.
But I replugged it and now everything is working!
Great website, guys!!
Markus
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
markus 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 1,947
