跳转到主内容
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
167 个问题 查看全部
after getting wet it will not charge
Is the voltage regulator on the daughter board?
My S8+ indicated moisture when I plugged in the charging cable, the next day it did not but It will not take a charge. Even wirelessly. It was working fine, just not charging. Once the battery went down the phone will not power on. When charging now there is a circle with a lightning bolt on an otherwise blank screen, normally it has the percentage charge also. last percentage charge I saw was 0%.So I think it is the voltage regulator that is fried. If it is on the daughter board I can pillage one from another Google Locked phone and fix mine.
You think this will work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Replace the charge port. I see this happen quite often after they get wet or even just out of nowhere. Just make sure you get the port that corresponds with your model otherwise you’ll end up with a “No Sim” error message.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
charles atchison 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 193
