跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
109 个问题 查看全部
Black line on the bottom of the display and then restarts
I replaced the screen on my personal device and went for the cheaper LCD option, However I am noticing when I am doing graphic intense games such as pokemon go and I am in direct sunlight or charging with a fast charger, a black line will appear and the phone will freeze and then the phone will restart about 5-10 seconds later. I was wondering would this be because of the LCD display or does the display that I purchased have an issue that shouldn’t be there when you go for the LCD option.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Bonjour,
C’est tout simplement votre LCD qui est d”défectueux, il faut le faire remplacer et faire jouer la garantie la ou vos l’avez acheté.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for that, in your opinion do you think getting a new lcd display is a good choice or should I wait until I have the money for a OLED display, which is about $200 more in my currency.
完成的
If you are ready to tell the difference an OLED is always better, but if you are in a hurry, the LCD will do the trick.
完成的
添加一条评论
添加你的答案
Colin Peart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 49
