跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
368 个问题 查看全部
PS4 keeps making eject sound while on
So just recently my pro keeps making the beeping sound like trying to eject a disk but there is no disk in it. I’ve tried putting some bottles caps to elevate as I read on google that may help. Even took the front cover off and loosened the screw but still no luck. Just tried inserting a disk and it automatically throws it back out. Any feedback is much appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
I have had this problem too but was with the PS4 slim and the old PS4 models. Those issue of ejecting disc same time its inserted and periodically generating the disc eject motion inside with no disc in it is due to a faulty eject button of the console. Try checking if your eject button does the same sound and feel as that of the power button. If it isn’t then the eject button is faulty. Another way to check if eject button is faulty without taking it apart is by just turning on the power point power of the console but not pressing the power button of the console. If the console does the consecutive beep that relates to no disc inside to eject then its a faulty eject button.
Hope this helps.
这个答案有帮助吗?
得分 0
1条评论:
How did you fix it then?
完成的
添加一条评论
I have the same issue, were you able to fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eddiec235@gmail.com 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 62
总计 2,285
