跳转到主内容
Repair and disassembly guides for Sony DVD players.
65 个问题 查看全部
Change amp board on sony bvd e3100
Changed amp board on sony bdv e3100 home theatre system. The dvd worked for about 10 minutes and then the volume went out .No sound since but all other function are working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hola, tengo el mismo problema, encontró la solución?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @hurryharry ,
Here’s the service manual for the player that may help.
Note: The title of the manual says HBD-E3100 but it also says that this is the amplifier, video, HDMI, BD/DVD/CD system, USB, LAN, wireless LAN, Bluetooth, NFC and FM tuner section in a BDV-E3100 player.
Follow the Troubleshooting flowchart from p.34 to find out what has failed and then use the schematics to find out why it failed.
The fault may be obvious as a failed component on the amp board i.e. burnt out component so again the schematics will help.
Sorry to be so vague but when there is a failure you need to start testing and using the schematics as it could be any number of things that caused the failure. At least you’ll have the manual to help you
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Terry Branch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 196
