跳转到主内容
The Samsung NX3000 is an interchangeable lens camera released in May of 2014.
11 个问题 查看全部
Samsung NX3000 camera stuck during Firmware upgrade.
Was doing an upgrade from 1.02 to 1.11 on Samsung NX3000 camera. but the process stuck just under half way. Now it seems ‘bricked’ and will not operate. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi Joe,
Unfortunately due to the way firmware is written to electronics, if the process is stopped during the firmware update before completion then the device is ‘bricked’ as there is no firmware or a corrupted firmware on the device. Firmware updates overwrite the original firmware data during the update so stopping the update leaves you with an unusable firmware and therefore an unusable device. The best you can do is talk to Samsung support about this issue but there is unfortunately not much you can do yourself to fix the problem.
这个答案有帮助吗?
得分 1
2条评论:
Thanks - I guessed that would be the answer. Kind of disappointing having only bought it in near new condition 2 days ago!
完成的
I had the same problem, exhausted all avenues with Samsung, the repairers they recommended didn't even repair their cameras here in Australia. after trying to find a solution Samsung advised me they don't supply support for their cameras !! Now isn't that great !!! Bloody useless company.
完成的
添加一条评论
Hello Joe,
https://www.samsung.com/ie/support/model...
这个答案有帮助吗?
得分 0
3条评论:
Thanks- ill give them a try
完成的
You're welcome ☘☘☘
完成的
Don't waste your time
完成的
添加一条评论
添加你的答案
Joe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 416
