跳转到主内容
Repair and disassembly information for the fifth-generation 12.9" iPad Pro featuring Apple's M1 SoC and an XDR mini-LED display.
26 个问题 查看全部
Is there a way to manually light the LEDs?
So I tried not breaking the screen when following the teardown instructions, but the connector got a tear and the screen got a crack.
I was wondering if you guys would know how to manually put power to the mini LED backlights, so I can still use it for something.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
well if you broke the screen and the connecter then its your bad, and since the mini led’s are so small you can’t extract them,and since apple also harasses 3rd party repair,i dont think you can manually light them and use them.
这个答案有帮助吗?
得分 0
添加一条评论
If you like trying tinkering with this kind of things, you could try to throw 1 V to each rail with the ground on the first or last pin, Probably nothing is gonna happen, but at least you tried.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lex van de Wiel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 551
