跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
253 个问题 查看全部
I have a blinking file folder on screen is my ssd shot?
I read through some other questions and answers I haven’t been able to pull anything else up. I’m up for any suggestions. Since the ssd is soldered in does that mean a full logic board repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Its still a bit early to conclude that!
A blinking question mark in the folder is just telling you your OS files are missing or it could be the worse the drive has failed. If your Mac starts up to a question mark
Hopefully you’ve been good at backing up as you may end up not being able to recover anything on the drive.
So I would start your system in macOS recovery and then get to Disk Utilities to see if repairing the drive fixes things. If not then you’ll need to either run Internet recovery to install a fresh OS onto your system or create a bootable external disk if you need to try to recover any of your stuff that’s still on the drive using Time Machine. (all referenced in the link above)
这个答案有帮助吗?
得分 0
添加一条评论
@matt124 The first thing to do is shut down the mac and press the power button then press and hold the option key button and R keep holding it until you see the mouse and some drives. If you do not see any drives but you see the mouse then it means that the drive cable or the drive itself is bad and needs replacement. If you see two drives. Click on the drive that’s labeled Macintosh HD or macintosh SSD or untitled not the drive recovery.
if the unit boots up great. you can now restart the unit and perform an NV RAM reset which should take the computer back to normal.
If the unit is stuck on the loading screen for longer than five minutes and will not reboot. Restart the mac and select the recovery partition and boot into that. The press and hold command R while pressing the power button is to launch a second recovery partition drive. which is part of the APFS. Once in the recovery UI click on utilities, select the main drive to perform a permission disk repair. Restart the unit then try and reboot the Mac in the main drive again.
SPAM removed!!!!
这个答案有帮助吗?
得分 0
1条评论:
@crispuswk just a bit of advise since you are new on here. Be very selective about linking to your own business etc. since that can be considered SPAM. The mission on here is to help others in a public forum not to drive our own business interest etc. Do feel free to do some marketing about your business, skills etc., on the About page of your profile but not in the answers. Welcome to the iFixit community.
完成的
添加一条评论
添加你的答案
Matthew Long 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 54
