跳转到主内容
Device repair guides for the 2018 Motorola Moto Z3 smartphone, model number XT1929-17.
19 个问题 查看全部
I just changed the battery, now it won't charge.
I’m wondering if I damaged the charging circuit, failed to reconnect things properly, or if it simply needs some kind of reset.
The new battery showed 37% when I powered the phone back up. I followed the advice to discharge it completely before charging, and kind of forgot about it. I did note that the display seemed to be stuck on 37%. When I got back to the phone, it was off from being completely discharged.
I have a good charger and good cable; it works fine for other phones. The phone was charging properly before I swapped batteries. I left it on the charger overnight and it’s still at 0%
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Get another battery or another charger.Be sure the battery matches the original one.Or the charger.
这个答案有帮助吗?
得分 0
7条评论:
or try the rese-and WAIT the phone is at 0 percent.
完成的
The replacement is a match for the old one, Motorola brand and model. The charger works fine on another phone. Did I kill the battery by discharging it completely?
完成的
I took the phone apart again today and connected the old battery without removing the new. Brought the phone back up and it won't charge the old battery either. I think I killed the charging circuit. Both the battery and the external charger work fine on their own.
Is there a way to replace or reset the charging circuit?
完成的
Send it to a tech repair station or look inside it then look up the model to see if its a match.
完成的
Oh the battery is a match alright
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Matthew Wheaton 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 26
总计 139
