跳转到主内容
3rd Generation high performance tablet computer released by Apple in October 2018. Models A1876, A2014, and A1895.
My iPad pro 2018 12.9" lost backlight
Hi all, this is my first post. My iPad pro 2018 12.9 inch (model 1895) went black during usage outside at 28°C. Then I noticed that the actual display shows picture but the backlight is not illuminating any more. I have opened the iPad and checked the logic board for visual damage but everything seems to be OK. The filters next to the display connectors are also ok. Does someone has experienced this issue or has the schematic for my ipad? Would be very helpful
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
How did you test the filters
完成的
I have used this video as a guide: https://youtu.be/6FnO1oY-voM
It is not the same model but has a similarly design at some circuits.
I did not had any burned filters but found a burned cap (optical burned but not shorted).
完成的
Do you have a multimeter
完成的
Yes. Do you have schematics available for this model which is showing where the backlight circuit is located?
完成的
添加一条评论
1个答案
The backlight on the screen might of failed or the backlight circuit failed on the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Serdar Yagcioglu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 1,437
