跳转到主内容
A 14.1 MP camera released in 2012. The Nikon Coolpix L310 support and repair information.
16 个问题 查看全部
Can't save Images on the sd card
Can somebody help me?
My problem is the camera won't save Images on my SD card, I have inserted the SD card, but when I take a picture, the picture is not saved on the SD card, what do you think the solution is?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Ansrattlexnake [Tagdzsi]  first you have to make sure that you have a card that is compatible with your camera. Next make sure that it is not write protected. Once inserted, your camera should ask you to format your card. Do not format your internal memory since that will lead to loss of your pictures. You may want to try a different memory card and check that out. If you need the user manual for your camera download it from places like this
这个答案有帮助吗?
得分 3
1条评论:
Nice!
I tried to open the "Write Protected" and it works like a charm!
Thank you so much!
完成的
添加一条评论
My SD card captures my digital images but once home they to not appear in camera or PC. Nikon 5000D
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ansrattlexnake [Tagdzsi] 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 82
总计 1,462
