跳转到主内容
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Why doesn't my PS3 Controller Pair?
I had my PS3 controller disassembled so I could clean it. Once I had it cleaned and reassembled, I went to power it on and I could not get it to power on with the Sony button.
I powered it on by plugging it into my PS3. It turned on with four blinking lights, but after ~15 minutes it never paired with the PS3. I disassembled it and clicked the reset button and re-seated the battery, but these didn’t make a difference.
Any clue as to what may be causing the issue? This controller was working perfectly before I disassembled it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can you try rebooting your device?
完成的
添加一条评论
1个答案
已选择的解决方案
The ribbon connector that connects the button membrane to the motherboard wasn't making contact on my controller. There is actually a little rectangle of black padding that goes between the white plastic shell and the ribbon cable. There is even a groove in the plastic that the pad fits perfectly into. It had fallen out and I didn't know where it went. But as soon as I placed it back in, the controller powered back on and turned my console on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jesus Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 236
