跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
Won't Charge Or Displays Caution Sign During Power On Attempt
I know this is a pretty dated piece of tech, but I have pictures and contacts in the device that I need. I’ve tried different chargers and different plugs, but the result is the same. Changing batteries have given me the results of a black screen or a caution sign inside the “charging battery” animation upon start up. I’m just looking for some help so I can get what I need off of there. If anyone has any ideas I’m open to any and all of them. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I repaired alot of these devices back in the day and the fault you are describing is almost always the Charging Port Flex Cable.
这个答案有帮助吗?
得分 0
3条评论:
What exactly do I have to do to the flex cable? Is it loose or do I need to replace it? And where is it located?
完成的
@jjmarcus143 Sorry, I thought it was a Galaxy S4 for some reason. Galaxy S3 is just a port, not a flex cable. But unfortunately, I'm not sure what could cause this on this model.
完成的
Dang. Alright I appreciate the response.
完成的
添加一条评论
添加你的答案
Jamarcus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 22
