Best way to clean evap coil
I have practically no airflow in this truck. Been that way since I bought it 2mo ago. Have pulled blower motor under dash and found it is clogged to !&&* and back. Best way to clean it without removing dash?
Update (06/09/2021)
I could not remove the accumulator from the suction side of the evap, so I couldn't pull the coil when I was replacing the dash. Went in with vacuum and cleaned out everything I could, then sprayed some cleaner on it and washed it off. Anything I missed? Not pulling the dash off again so any additional ideas would be helpful
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
