跳转到主内容
A single pass flatbed scanner with USB interface.
2 个问题 查看全部
What are the specs for the power adaptor for Mustek 1200 CU
I lost my power adapter for Mustek 1200 CU flat bed scanner 80-063-04010. Would appreciate if there is an available photo of the adapter too.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Here is the photo of the original power cord plug of the Mustek 1200CU Scanner
DVE “DV-1280UP” -
INPUT: 230V ~ 50 Hz 0.09 A
OUPUT: 12V= 800mA 9.6VA
这个答案有帮助吗?
得分 1
评论:
Thank you very much for answering my question and indicating the important details. Very helpful. I hope I can find a replacement here in our area so I can put the unit into use. :-)
完成的
Would you know what is the connector or tip size of the DC plug of the original power cord plug for Mustek 1200 CU? The photo does not include the connector tip. Thank you.
完成的
添加一条评论
最有帮助的答案
@brgob this scanner should actually be powered through a USB port. You can always use something like a 5V 2.4A USB power adapter and connect that via a USB==>>USB mini-B port cable. Post some pictures with your QUESTION of what your power cord plug on the scanner looks like. It should be a mini-B port.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
评论:
thank you for your reply. I can not attach a photo of he power cord because that is precisely what my question was - as I said, I lost the power adaptor for the scanner unit and that is why I was asking for the specifications so I can look for a compatible replacement. Actually, the scanner was a hand me down from my brother and I just discovered that the power cord or adaptor was missing. Thank you again.
完成的
添加一条评论
添加你的答案
Bet 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 4
总计 52
