跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
92 个问题 查看全部
Fans are spinning normal but screen stays black and no startup chime
I recently bought this mac, and I wanted to factory reset it. While it was rebooting, I accidentally unplugged it and the screen has not turned on since. I tried to do a PRAM reset, but it did not respond. I have tried to make a bootable disk, but that dod not work either. The fans spin and I think the magic keyboard connects to it but the screen stays black.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
See if you can boot up in Safe mode, press Shift (⇧) key during startup
Reference: Mac startup key combinations
If that fails time to visit an Apple Store
这个答案有帮助吗?
得分 1
添加一条评论
Try using a wired USB keyboard (any will work), The driver for the magic keyboard probably is not loading. Then try rebooting in Recovery Mode and run Disk Utilities.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the response! Sadly, I tried this and the screen still stays black.
完成的
with the wired keyboard try Dans solution. that failing do a SMC & PRAM reset
完成的
添加一条评论
添加你的答案
Papa Gandhi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 42
