跳转到主内容
iMac Pro,Apple 迄今为止性能最强的 iMac 。可选配置包括3.2 GHz 8核,3.0 GHz 10核,2.5 GHz 14核,2.3 GHz 18核 Xeon W 处理器。EMC 3144 / A1862 (ID iMacPro1,1)
40 个问题 查看全部
Can I replace an 8 Core Xeon processor with a 18 Core Xeon Processor?
Can you replace the 8 core processor in a iMac Pro with an 18 core processor in a
iMac Pro?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Yes! There is no problem as long as you use the correct CPU! 18-Core Xeon W-2191B
Now before you do this consider the clocking Vs threads issue!
  • 3.2 GHz 8-Core Xeon W-2140B
  • 3.0 GHz 10-Core Xeon W-2150B
  • 2.5 GHz 14-Core Xeon W-2170B
  • 2.3 GHz 18-Core Xeon W-2191B
A single threaded process will run faster on your current system and much slower on the 18 core! As the clocking has a large effect here.
But!! A multi-threaded application can leverage the multiple cores of the CPU, but you do need meter how many cores makes sense given your work load.
I often find people go crazy going with too large a chip when a middle version would make more sense!
So if your multi-threaded work load is using more than 2/3rds of your work day then consider the bigger chip, I would still see if the 14 core will be enough. If it’s less than 1/2 of your work day maybe the 10 core is enough.
Just like Goldilocks and the three Bears! There is a balance! Not going too small or too big!
Here’s a guide to get the display off iMac Intel 27" Retina 5K Display 2019 Display Replacement we don’t have an guide’s explicitly for the iMac Pro. Review the iMac Pro拆解 to an idea what’s involved.
iMac Pro图片
指南
iMac Pro拆解
难度:
中等
iMac Intel 27" Retina 5K Display 2019 Display图片
指南
难度:
中等
15 - 40 minutes
这个答案有帮助吗?
得分 4
添加一条评论
Yes, you can replace but you should not doing it because your computer components will not bear the 18 core Xeon processor but if you have the TDP then it is possible
这个答案有帮助吗?
得分 0
1条评论:
FY - Apple sells the system with the 18 core chip so there is nothing wrong with the configs TDP.
完成的
添加一条评论
添加你的答案
Doug Moore 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 83
总计 1,330
