跳转到主内容
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
Wii Disc Drive Broken Gear - Possible to Fix?
I have a wii disc drive that will accept discs, but will not eject them. Upon tear down the disc drive makes some noises presumably coming from this one gear i noticed. On closer inspection it seems this one plastic gear is slightly cracked? Is there anyway to repair this or, is buying a new disc drive my best bet? Attached is pictures.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Macy!
It’s a unlucky part which is broken. It will be difficult to find the part you need to replace. So those are the options:
  1. You can buy a new working drive and replace it (PCB does not need to be swapped for Wii). And strip the broken drive for parts (laser, rotor, worm motor and more..)
  2. You can buy a broken drive and take the good parts out (including the gear you need) and put it in your old drive.
I don’t think you will find the part that easy. You can always try to search for it (I did too now, but didn’t find the part you need).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Macy Hata 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 1,530
