跳转到主内容
加入维修社区 - 创建账户
50" Plasma TV by Sanyo released in 2007.
Where do I get the fuses?
I can't find the fuses to my TV anywhere.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Do you know if a sanyo fvf5044 has fuses? Mine doesn't turn on. Im searching in google but nothing about this model comes up. Please help!!
完成的
@mrsmdo18 it has fuses but those are on the power board and it's a differnt type of TV. What are the issues with yours? What have you checked?
完成的
I got a old Sanyo speaker system and the back fuse box broke and I don’t know how to get new fuses in the town I’m in
完成的
添加一条评论
2个答案
已选择的解决方案
You can get them from here as well as many other places. you just have to know which fuses you are looking for. I believe even your local Radio Shack will have those...F601 for your TV is a 250V 10 A fuse and the Sanyo part number is F32S10RA2LTTL Hope this helps, good luck
这个答案有帮助吗?
得分 2
5条评论:
Is there a list somewhere that equates the numbers by the fuse holder (i.e. F180) to a fuse number so the fuses can be located and purchased? Thanks!
完成的
Joseph Irvin, same TV? That usually can be resolved by looking at the schematic etc.
完成的
It is a Sanyo DP50747. I've looked at the repair manual which seemingly lists all electrical parts except for fuses.
完成的
Yes I checked myself and that is where the manufacturers always get us on. Missing information, only half information if even available is the trend. Goal is to prevnt anyone from fixing anything so that we rely on the big companies. Sometimes, it works if you can find out where the board comes from and try to find the actual schematic for it (not from the service manual of the TV but separate from it. The boards used in this TV may not all/none been build/designed by Sanyo but somebody else. That way it might be possible to cross reference.
完成的
Eureka! Tricky these Chinese ... Beside each fuse holder is a tiny triangle that has the fuse designation inside it. (We had to use a magnifying glass to find and read them. ) For example, reading down from the top it says: 250V, T5.0AH. This translates to a fuse designation: T5.0AH250V. In other words, it is a 5.0 amp 250 volt ceramic fuse. In this TV they are 5mm X 20 mm in size.
完成的
添加一条评论
Hi,
I know the fuse says, FT 8ah 250 vp.
The item number with Buss is: S 505 8 R You do need the space between the 5 space 8 space R.
This is a ceramic fuse 8 amp 250 volt slow blow 5 mm in dia. and 20 mm long.
THe Graybar or Grainger is a five pack its Item number 1XFF4.
The NTC brand(i guess) is 74-55C8A-C. I bought these for pack of 5 for $3.00.
We put it in and it is working...YEs...
这个答案有帮助吗?
得分 1
1条评论:
What happens if I put a fuse in an it works but not the right fuse for TV replacement
完成的
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 9,758
