跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaCentre AIO 510S-23ISU 是一款于 2016 年 9 月发布的 Windows 台式电脑。它是一台一体机,意味着该设备将显示器和电脑整合在了一个机身中。
Lenovo AIO Won't Safe Boot, System Restore or Boot From Recovery USB
Hello,
My client has the Lenovo F0D3 and it is stuck on the Lenovo screen boot loop.
All attempts to safe boot, boot to recovery mode, boot from USB drive with windows for re-install don’t work. With the USB recovery stick in, the windows logo pops up for only 2 seconds before going back through the lenovo / windows screen flash boot loop.
I played with bios boot options from UEFI to legacy and nothing.
I correct the mobos time and dates and nothing.
None of the function keys work except for bios enter and mother board repair options which scan HDD for errors / bad sectors but found none.
No Windows systems seem to be loading.
What could cause this and how do I fix it?
(PS. I’m thinking of removing the HDD from the AIO PC and wiping it with killdisk then trying to reinstall windows on it… but would rather not have to, why wont any recovery modes work?!)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @zstechfix ,
As a suggestion try booting a standalone program (example only) from a USB i.e. one that doesn't require a HDD or Windows to run, and see if the PC boots/runs OK etc. Disconnect the HDD from the motherboard.
I'm not suggesting this program just because it tests the ram but in doing so a lot of other hardware resources are also utilized as well, except of course the HDD sata controller.
Just trying to see if the PC will still boot/run successfully, at least from a USB.
Did you restore the BIOS to factory default just in case it was corrupted?
Also check the onboard RTC (coin cell) battery on the motherboard and make sure that it is >2.5V DC. Removing the battery and the time taken in testing it will also default the BIOS.
Have found in the past RTC batteries with <2.5V DC that the BIOS can sometimes become corrupted causing strange things to happen from no startup at all, to not passing POST to not booting etc
完成的
@jayeff Im trying to fix it without opening it up, seems tricky / damageable to open. If I could / did open it I will try that and also just reset the HDD manually.
Its strange it cannot accept any recovery options nor do F keys work for windows operations, only lenovo / mobo operations
完成的
@zstechfix
So the standalone program test didn't work either then?
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @zstechfix,
If you decide to open it up here’s the hardware maintenance manual for the AIO that will help.
If you need any parts here’s the parts list. Just click on Select Commodity to get the part type and then when you have it search online using the part number only to get results for suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
Before wiping hard disk, you may check this page: http://www.minitool.com/news/cant-boot-f...
Hope it will work for you.
这个答案有帮助吗?
得分 0
1条评论:
Thanks, Yes the boot disk is formatted correctly and has been used before.
完成的
添加一条评论
添加你的答案
ZsTech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 2,213
