跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
Lower battery connector overheating upon battery replacement
I recently had an iphone 11 pro max heat up and go dead on me. Guessing it was the battery, i replaced it, and immediately upon plugging in the new lower battery cable (into the power distribution board thingy near the lightning connector) that plug began to get very hot, to the point of burning my finger within a few seconds. I unplugged it and, through process of elimination, tried disconnecting every other component from the lightning connector. Each time the battery cable still got hot. I tried cleaning out the battery connector and the charge port with alcohol and compressed air to no avail. I have also had issue with the lightning port intermittently not charging before. I am thinking that I have a short somewhere in the lightning port or the greater component including that port, but I wanted to ask: is there any world where that behavior is normal upon pluggin in a new battery? Is it possible that replacing the lightning port may not fix my issue? Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You are right thinking you have a short. The shorted component will be on the logic board on the PP_VDD_MAIN circuit. There are two sections of the board that are soldered together, the short could be on the bottom half which means the board will need to be separated to find the faulty component.
If you haven’t got the required experience and microsoldering skills you will need to send it to a reputable repairer.
这个答案有帮助吗?
得分 2
4条评论:
This is helpful, but the issue persisted with the logic board completely disconnected. This phone has two battery cables, one to the logic board and one to the lightning connector/speaker/taptic engine/wireless charge port. With the logic board battery lead disconnected AND the lightning flex cable to the logic board disconnected, and just the lower battery lead plugged in it still heated up. Does this eliminate the logic board from the equation?
完成的
@Seth Waag-Swift So it is only the charge flex assembly getting hot? If nothing is connected to the logic board replace the dock assembly.
完成的
Yes thats correct. I will do that thank you!!
完成的
Did this fix your issue? I am having the same issue with an iPhone 11 pro.
完成的
添加一条评论
添加你的答案
Seth Waag-Swift 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 699
