跳转到主内容
谷歌第三代 Pixel,是谷歌首款"刘海屏"手机。配备了一块 6.3英寸 QHD+ OLED 显示屏,内存有64 和 128 GB可选。三款配色分别是(差不多)白,(就那么)黑,(不算太)粉。
77 个问题 查看全部
Battery won't charge after replacement
I recently replaced the battery in my Pixel 3 XL and now it won't charge and when I go into the battery menu on the phone it says Unknown battery. The microphone and speaker are also not working. The phone also has the system UI crash everytime you boot up the phone. Any clue what is going on or if it is even fixable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You can try a factory reset to rule out glitches in the software interfacing with a new battery. Although there's always the possibility that you installed a non-OEM or subpar battery, or just didn't do it correctly at all.
This is could be due to a hardware issue. Try the following options to troubleshoot:
  • Use a different charging cable and adapter.
  • Try charging the phone from a different wall charging port or a computer USB port.
Ensure your charger and cable is OEM or high quality, that your charging port is not dirty or otherwise impaired, and reset your device. If all that doesn't solve it, then I'd guess your battery itself is to blame.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mitchell Haley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 412
