跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
How to Align iPhone XR screen properly
I was installing and I fix it replacement screen and I was wondering I can’t get it to Fit in tightAnd when you tap on the corner the screen moves up and down a little bit I was wondering is there a way I could fix this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Push the top two prongs in at an angle, then walk down the phone with your thumbs pressing on the bezels. Also I would recommend applying a new water adhesive seal (If you haven’t already) as it will keep everything in place. If neither of those work, send it back and get another replacement screen assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jesse 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 45
