跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1647 个问题 查看全部
Have to keep replacing water filter.
Hi,
I have a Frigidaire refrigerator bought in 2015. Earlier this year in January, the water dispenser stopped and ice was not being made. I replaced the filter with another Frigidaire one and it worked again. 3 weeks later it stopped, so I bought a 2-pack of off brand ones. Replaced it again and it worked for another 3 weeks. Now it stopped again and replacing the filter makes it work again right away. I can’t figure out what the problem is and why the original filter, no longer available, worked for 5 years without any issue. Please advise. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi Mike!
I think that problem is with limescale depositing on the pipe walls - especially if you have hard water.
For 5 years it’s possible that limescale stucked in pipes in refrigerator.
Try to get to pipes and clean them.
这个答案有帮助吗?
得分 0
添加一条评论
The replace indicator on most, if not all, refers is a timed function. With 2 seniors in the house we don’t use much water, but the timer does not wait for us. As such, blocked pipes are not going to trigger it. The timer circuit is probably on the control board and is probably controlled by a capacitor that is going bad therefor reducing the time to 3 weeks instead of 6 months. If you are into fixing it you can eyeball the board to see if any of the cap tops are starting to become convex. They must be perfectly flat or slightly concave. Removing a filter and reinserting the same filter will prove the point.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike Zee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 26
