跳转到主内容
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
175 个问题 查看全部
Switch Lite Wont Turn On
A good few times now after being put on charge overnight the console will not power on. I’ve tried resetting by pressing the power button for 12 seconds etc to no avail. All times before now the console has come back on by itself after being left on charge for further time. There has been good amounts of time between this happening so despite happening a total of four times now the console functioned perfectly fine for the months in between. No charge issues, battery seems fine etc.
This time however the console hasn’t come back on and its been a couple days now. No damage, water or physical as happened. Anyone have any idea why this has happened all these times and why possibly the console hasn’t come back on this time around?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Jamie!
Could be a lot of things. Motherboard fried, charger which is faulty, faulty battery or something else. I think it’s motherboard related as you describe it. I advise to test with another original charger first. Do you still have warranty on this device? Otherwise I would return it.
这个答案有帮助吗?
得分 1
3条评论:
I have tested with multiple official chargers already to no joy. I don't think it's a battery problem as the console has worked fine in between stints. Unfortunatly the console is no longer under warranty and I've already had it fixed once by Nintendo (broken charge port). Going to send it off to Nintendo hopefully the don't charge me an arm and a leg again as the issue has not been caused by damage etc.
完成的
Hi Jamie! The motherboards are very expensive and hard to find. Let's see what Nintendo has to say, I think you do good by contacting Nintendo for this issue.
完成的
I was plugging & playing on my Oled. @ 87% stopped charging altogether & will not charge.. Green light flashes off & on the dock. Turns off & on np. Never had this happen before:( pls help
完成的
添加一条评论
Plug the console in and hold down the volume buttons. The + and - together it will go to factory reset.
If it does not..
Well it's not the problem I thought it was.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jamie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 13
总计 1,024
