跳转到主内容
Can I upgrade the main logic board with one containing M1 chip?
Is it possible to upgrade my MacBook Air 13” Early 2015 A1466 with a new main logic board that has the Apple M1 chip?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
Hi there, Scott!
From my understanding, I do not believe that would be possible. As far as I’m concerned, you would only be able to replace it with a logic board of the same year + model of your device. I would be surprised if Apple made the logic board similarly enough to where that would be possible as that would mean people wouldn’t need to buy a whole new computer, but instead just a part—and I don’t think that’s how they work. I could be wrong though. However, I didn’t want your question to go unanswered.
这个答案有帮助吗?
得分 1
评论:
Thats correct! Apple altered the design enough to prevent swapping out the logic board to an M1.
Your only option is to upgrade your logic board within the same series.
完成的
Thank you, @danj. You're the cat's pajamas.
完成的
@suehyphenlyn - You had me thinking, do cat's wear PJ's? Cat Pullover
Enjoy the pic ;-}
完成的
添加一条评论
添加你的答案
Scott Speckman 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 24
