跳转到主内容
Repair and disassembly information for the 2020 refresh of the MacBook Air. Released in March 2020.
38 个问题 查看全部
Replacement keycaps are too thick?
Hi,
I have had to replace the keycaps on my A2179 (early 2020). But the replacement keycaps - from a trustworthy source - are thicker than the original ones. That means they are slightly higher when installed. The description says they are keycaps for A2179 and A2337.
The original key kaps are 1.4mm thick, the replacement ones 2mm. So the key caps are slightly above the line of the housing whereas the original ones were flush.
Is this a problem?
Can I use them? Or do I risk damaging my display?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
Did you remove the key and the keycap?
这个答案有帮助吗?
得分 0
评论:
I had to remove the keycaps. The previous owner broke some, so I replaced all. Halfway through I noticed the difference in thickness. Scissor hinges are the originals.
完成的
添加一条评论
添加你的答案
Numazuchi 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 8
