no video, audio ok
the board on the left side is burnt (screen power control #1). the long board to the left of it may need replaced also. Need part numbers and where to order. thanks
You can download the the service manual from here It does have the schematic and will allow you to identify the boards. I would think that the "burnt board" had a couple of bad caps on it. That may be all that is needed. It would help us to post an image of the burnt board. You can shop ebay.com for parts needed, or use this site. The best way of getting your numbers might be of the original boards. I know as a fact that this model has at least three different power boards, so be cautious. Good Luck
这个答案有帮助吗?
+ replacing caps is cheaper by far
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 797
