iMac 27 “ 5k 2015 half screen rebooting every mint
Hello everyone!
any help with this issue please?
Ouch! You damaged the display in taking it off. Did you use the proper tools and techniques from our guide here 2017年款27寸 iMac 显示屏更换 and the pizza tool in this kit iMac Intel 27" (2012-2019) Adhesive Strips as well as the Plastic Cards
这个答案有帮助吗?
Thanks for replaying,
I have removed the LCD professionally but this issue was there before I removed the LCD and I was the first who removed it, does this mean I need a new LCD?
If so, then why when I use an external monitor I don’t get a picture?
Also, when I start the iMac in Safe Mode it works and no issue with the LCD!
@iphix - It would have been helpful getting this additional detail before now.
Your system has two GPU units the discreet AMD Radeon GPU and the integrated one within the Intel CPU, HD Graphics 630. So when you are in Safe Mode you are using the Intel integrated Graphics.
So you appear to have a bad AMD GPU. This will require a new logic board.
@danj Thank you Dan This what I thought as well at least, my LCD is not damaged :)
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 118
