跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
264 个问题 查看全部
Noise coming from the screen of the iPhone XR?
My iPhone XR screen got hit a bit hard by my arm last week by mistake. On the same day of this incident, the screen made a weird loud noise when I swiped up but the problem is that I am not sure if it is the screen or not. But thankfully this noise happened once only. A day after, I became a bit worried if I caused any damage so I began observing the phone. I realized that sometimes the screen makes a noise when I touch it. Sometimes the screen won't make any noises and is completely fine. The noise is different every time, sometimes it's like a clicking noise.
Could it be from my screen protector? Or is it hardware damage? My screen protector is a bit thick so I am not sure if it coming from that screen protector.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
The only thing that could be making noise like that would be the vibrator in the device. Perhaps you knocked it loose or damaged it in a way that is causing it to make these sounds. Does the vibrate function still work normally when using the phone? Are you able to open up the device to see if there are any loose screws or if the taptic engine is properly secured?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SamiWyatt 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 5
过去的30天: 6
总计 27
