跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
274 个问题 查看全部
Purple flickering lines on screen
Hello
I have the following MacBook Pro model (MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports)// 2,3 GHz Intel Core i5// 8 GB 2133 MHz LPDDR3// Intel Iris Plus Graphics 655 1536 MB) and suddenly the screen started flickering with purple horizontal lines. The lines do not appear on an external monitor that is connected to the computer, they only appear on the Mac screen.
I have tried rebooting with the following options and it doesn’t work. Any ideas?
1) Option, Command, P, and R
2) Control, left Option (Alt), right Shift
3) Shift, left Control, left Option (Alt)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Due to the fact your only facing the issue on the MacBook screen itself, it would seem you have physical damage. It’s either gonna be the LCD cable, a board Issue or god forbid a damaged screen :(
这个答案有帮助吗?
得分 0
3条评论:
Thank you for your prompt reply. I was wondering whether it is a known defect for this model, given some issues such as this one: https://support.apple.com/13-inch-macboo...
完成的
The LCD cables are common to deteriorate over time that's why I mentioned this first :)
There certainly is a know backlight driver issue with most MacBooks, but as you see an image it would mean the backlight is fine.
I just hope for your bank's sake it's not the screen itself :(
完成的
@eazy_pc_repairs - Older Unibody the cable was often the issue! The newer Retina systems its a bit different! Think how Analog TV worked with the rabbit ear antenna you had to move them about to get rid of the ghosting. Now with Digital you don't get ghosting at all! The signal works or it doesn't!
Same thing here! Between the older LVDS signaling and the newer iDP/eDP signaling the retina systems use.
完成的
添加一条评论
Sadly, your internal display assembly will likely need to be replaced. These newer Mac’s tend to run hot and as Apple moved the T-CON board to be within the uppercase it tend to cook (pass me the BBQ sauce!)
Dust buildup in the fan blades and heatsink fins tend to be the largest issue. Using the system on ones bed or other cloth surface which blocked the air flow is another. Lastly, running the system hard without pushing the fans to the max using a good thermal monitoring app like TG Pro.
See if cleaning the dust out and pushing the fan helps. At least it can buy you some time. Here’s the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and the guide to put it in 2016后期带Touch Bar的13寸MacBook Pro 显示屏组件更换
MacBook Pro 13" Retina (Late 2016-2017) Display Assembly图片
产品
$454.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Myrto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 41
总计 2,870
