Anyone identify these micro components?
Hey peoples,
I was replacing some parts, and put the machine back together to find that it wouldn't power up.
Then I found these parts had come loose (on the part of the motherboard where the transistors and power cable enters in).
Does anyone know what they are ? (managed to resolder the brown one but the black one is crushed)
So, does anyone know how to fix? Alternate solutions I might not have thought of, or have any clue what the parts are?
As it would probably save me a bit instead of replacing the whole section of MB.
Thanks for any help!
4条评论
Can you identify its board number 820-xxxx
由 Dan 完成的
The resolution is way to low to see anything
由 very good hacker 完成的
@danj whereabouts is that typically located? There's a number near the underside of the CPU that starts off with 94v- E222034, A005012UU...... wasnt sure if thats it.
由 Duck 完成的
@sad_duck - It will be faint! Its part of the copper traces look for the 820- with four digits 820-xxxx I think its on the CPU side I don't have a 2019 board to look at right now. We need that to reference the schematics and board views to ID the parts.
由 Dan 完成的
