跳转到主内容
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 个问题 查看全部
Screen won’t work after replacement
I just replaced my screen after I shattered the entire lower half. My home button was destroyed in the process or when I broke the screen, not really sure. Well everything is put back together now and the screen won’t work. I know it’s “on” because when I plug it in it gives me the charging sound effect. I’m not really sure what I can do here. I can’t do a hard reset or even turn it off the regular way. It’s a huge bummer because other than the screen it was in perfect condition for almost 6 years old.
If anyone has any tips or ideas I would be greatly appreciative.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You could have knocked components off around the connector or blown a backlight filter. Shine a light on the screen and see if you can see the image.
完成的
添加一条评论
3个答案
最有帮助的答案
More than likely the backlight filter. It's pretty common with screen replacements especially if you don't disconnect the battery prior to connecting and disconnecting the screen.
这个答案有帮助吗?
得分 1
1条评论:
I did disconnect the battery and I can’t shine a light to it and see the screen. I’m going to try some of Steve’s suggestions and see how that goes.
完成的
添加一条评论
It maybe just needs a reset, home buttons can be replaced they will just operate at a home button without finger print feature, I suggest replacing home button then you can reset it easily.
if that does not fix then next step is to look at hardware make sure all plugs are not damaged and plugged in correctly and flex cables of new screen are not damaged.
if still not joy it could be faulty screen try another , did your old screen light up try it and see if it still lights up.
next step is logic board damage maybe back light this will require micro soldering to fix.
这个答案有帮助吗?
得分 1
添加一条评论
recheck all the connector involved with the screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maggie Phifer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 41
