跳转到主内容
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
147 个问题 查看全部
Ipad will not turn on after battery replacement?
As the title states, I replaced the battery in an iPad Pro 9.7”, and now the iPad won’t turn on. No LCD display.
I plugged the iPad into a laptop and it was recognized by iTunes.
The installation went fine and without problems, and I’ve done it before, so I’m confused what the problem could be here. I’ve triple-checked all the connectors and everything that could be loose to prevent the LCD from powering up, and I can’t find anything. Any advice would be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
was the battery connected when you connected the display? sometimes people can blow the backlight circuit when they connect the screen while the battery is connected. If you shine a flashlight on the display while attempting to wake it up or turn it on that's a quick and easy way to diagnose a blown backlight. also what did iTunes say when you connected the device? Was it in recovery or DFU mode?
这个答案有帮助吗?
得分 0
2条评论:
It is in recovery mode
完成的
@janedoethethird glad you got it resolved!
完成的
添加一条评论
添加你的答案
Jane Doe III 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 239
