跳转到主内容
The fourth-generation 4Runner incorporated serious changes to the chassis and body of the vehicle, but was targeted at approximately the same demographics as the third generation.
6 个问题 查看全部
One remote control for two cars!
I bought a used 2007 4runner.
It comes with two remote controls. I reprogram one of the remotes for another car.
Now the remote lock and unlock the two cars.
My question is
How can I rest the remote to use it for one car?
I hope you help me i will be grateful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You need to erase it from the ECU, depending o the other car you paired it with, some you can do by re-programming the key you want for that car and just don’t use the key you want to use only on the one car, on some cars that will remove any currently programmed remotes and only recognise the one you’ve just done, on some others you may need a car key technician to come and delete it via a computer, what is the other car you paired it with, is it the same Toyota?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
saleh algoraed 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 39
