跳转到主内容
An HP notebook laptop in the EliteBook series released in May 2013
3 个问题 查看全部
What is the cost to repair laptop's broken hinge?
One side of the laptop just started making sound when I opened it and soon I saw that one hinge broke. I'm unable to fix it myself. I need help regarding this or if you can tell me how much will it cost to get repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi @skaur ,
I don’t know what the cost would be, you would need to contact a reputable, professional laptop repair service and ask them.
If you wish to try repairing it yourself then here’s the maintenance and service guide for the laptop. Go to p.119 to view the necessary pre-requisite steps and then the procedure to remove the display assembly. It is during this procedure that the hinges can be accessed.
On p.38 Item #5 you will find the part numbers for the different types of hinges available, depending on the different types of LCD panels that can be used in the laptop.
Search online using the appropriate part number only to get results for suppliers of the part.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simran 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 17
总计 339
