跳转到主内容
Second generation Learning Thermostat from Nest Laboratories
20 个问题 查看全部
Why is the new battery not powering the device?
I received my new battery for my nest 2nd gen thermostat from I fix it. After I installed it, I charged it with a USB charger. After several hours of charging, the Nest device won’t turn on. When I plug it into the wall, I get a red blinking light at the top. I know I’m installing the battery correctly because, I was able to install the old one and get it to work. Is there a problem with the device or the battery? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
your best bet would be to contact customer support about getting a replacement battery. sounds faulty. ifixit is usually good about solving this for you.
good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brad Burns 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 42
