跳转到主内容
2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
964 个问题 查看全部
Boots Up with chime, blank screen nothing happens
My MBP suddenly doesn't turn on properly. The computer turns on, but to a blank screen. I hear the startup chime and the HD whirring. Also, after a few seconds the keyboard lights up.
I took out the HD for testing, and everything looks fine.
Any ideas?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 2
添加一条评论
iPhone 电池维修工具包
只要 $29.99
Buy Now
iPhone 电池维修工具包
只要 $29.99
Buy Now
2个回答
已选择的解决方案
Could be a GPU failure. The MBPs A1226 and A1260 use the problematic NVIDIA GeForce 8600M GT graphic card. If you don't have video on an external monitor contact Apple cause your computer could be repaired free of charge via the Apple special Nvidia replacement program.
这个答案有帮助吗?
按维修分数 3
评论:
Or if you have a spare computer you can use that as an external display.
Curious ! How would you do that ?
The easiest way is with ScreenRecycler but I'm pretty sure that won't work with a computer not turning on properly, so there are a bunch of ways to just connect to the LCD,etc. I've never tried or need to try any of them, however if you look at online forums you can find many ways, you need some adapters I think though.
添加一条评论
Try connecting to an external display, could just be a bad LCD.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Enon 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 4,595
