跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
208 个问题 查看全部
Backlight comes on, but no display after changing battery?
I just replaced the battery in my old Surface Pro 4. After reassembly, the device powers up and the backlight comes on, but nothing comes up on the display. I have connected it to an external monitor and confirmed that it is booting to the OS. I have also confirmed that the touch functionality is still working, by mirroring the main display with the external.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
If I’m not mistaken, when you disconnect and reconnect the battery in certain surface models, it blows a fuse for the image circuit. That or you could’ve damaged the display.
这个答案有帮助吗?
得分 0
添加一条评论
Have a detailed look at the connector under the microscope. I‘ve had no touch and found a stucked pin inside the connector on the board. Maybe this is the same with your connector.
这个答案有帮助吗?
得分 0
添加一条评论
Did you solve your problem?
I'm having the same issue, i get a subtle backligth but no image. Maybe related to a damaged ribbon flex cable?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Terry Laurent 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 78
