跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
System will not boot after power outage
Power outage is common thing where I come from , initially it would turn on nice after every power outage , then once power went off and it wount power on , I tried everything .
I opened system, when power cord was plugged in , I would see light #1 was on , and the light #2 would start blinking when I push the power button , there was no diagnostic info about that .
I kept on trying plug in plug out and suddenly it started , since then I bought APC UPS thinking it doesnot start because sudden power outage , but even if I shut it down but if the stand by power stops from UPS or direct supply it will go on that i will not boot up mode then again I will have to keep trying SMC , plug out wait 15 seconds then plug in then wait 5 seconds and power on , after 40 to 50 attempts it will power on .
bottom line it needs stand by power all the time , when its shut off . other wise it will not boot up for 1 or 2 days will take numerous attempts then it gets started .
I have changed the RAM , no effect , I thought pram battery must be dead but time and date are working fine without internet connection .
If you have any idea what could be possibly wrong with it , please advise .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Seems like you have a bad power supply. You will have to remove the power supply and have a look to see if there are any damaged components. Its good to have invested in a UPS.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aamir Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 36
