跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
466 个问题 查看全部
completely shattered any possibility to repair it?
so my grandma gifted me her shattered iphone xr, it turns on but back and front are completely shattered both rear and front cameras don't function as well as speakers so i was thinking can i buy a locked iphone xr (icloud locked) and just replace the logic board to have it fully functional?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You are taking a pretty high chance of doing this. I usually purchase phones in lots, and I’ve encountered 3 phones that had this issue. 2 were an iPhone X, and 1 was an XS.
I tested the models by doing what you said, swapping the motherboard into a good housing. Only 1 of the 3 phones I did it on ended up having sound and camera functionality back.
you can attempt this repair, as sometimes you can find a locked XR for cheap, and even if it doesn’t work, you will most likely get all your money back from reselling the locked XR
what I’m trying to say is from my experience, there is no guarantee it will work, and if the phone has a bend in it, there’s a pretty high possibility of having a board level issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andres ramirez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 55
